1995 Pontiac GrandAm Check Engine Light..
1995 PONTIAC
PAULROWLETT
I recently purchased a 1995 Pontiac GrandAm and the check engine light comes on when I accel then let off the gas..What would cause this also how do I check the codes? The connector looks like OBD1 but doesnt have the same pin outs..Also any clues how to change the 3 spark plugs in the rear side of the motor?
Jan 11, 2006 at 2:38 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Identify the exact engine and diagnostic system, then use a compatible scan tool to retrieve codes. Obtain the engine-specific plug-access procedure, including any required support equipment.
Guidance references and applicability
Source: This question and its visible discussion, including any clearly labeled editorial corrections. Owner reports are distinguished from other participants' experiences. Follow-up guidance is not a confirmed diagnosis.
Read the replies · Discussion summary and reported outcome
2CARPRO JACK
  • 11,533 POSTS
2CarPros editorial correction - October 12, 2026
The earlier scanner recommendation and suggestion to improvise engine movement have been withdrawn pending identification of the exact engine and diagnostic system. Use a scan tool verified to communicate with this 1995 Grand Am; connector appearance alone does not establish compatibility. For rear spark-plug access, follow the engine-specific procedure, including any required support and restraint. Do not loosen mounts or move the engine without the proper procedure and equipment.
Jan 11, 2006 at 7:14 AM
Discussion summary
The owner of a 1995 Grand Am reported an engine warning during acceleration or deceleration, uncertainty about its diagnostic connector, and difficulty accessing the rear spark plugs.
Reported outcome: No codes, component diagnosis or completed service were reported.
Connector appearance alone did not establish scan-tool compatibility. The earlier suggestion to improvise engine movement was withdrawn.
Read the original discussion
