1988 Other Pontiac Models timing belt replacement
1988 PONTIAC
RLDOUBLES
Engine Mechanical problem
1988 Other Pontiac Models 4 cyl Two Wheel Drive Automatic
where are the timing marks located on the crack pully---i found the one for the cam on the front of the head but i cant locate one for the crank ?
Jan 26, 2009 at 1:38 AM
HMAC300
  • 48,601 POSTS
put your crank pulley back on and set it at #1 and line the crank pulley up to the 10 degree BTDC mark. then line up your cam pulley to where it is supposed to be and install the belt. ADjust the belt and start the car. let the belt take a set and adjust hte tension to 30# putting the tension guage between the cam an dwater pump pulley.....
Jun 19, 2010 at 11:24 AM
