1967 Other Pontiac Models coolant leak
1967 PONTIAC
GTOSCOTTY
Engine Mechanical problem
1967 Other Pontiac Models V8 Two Wheel Drive Automatic 0
Hi, have a 1967 gto new motor, rebuilt radiator, new water pump, new t-stat . when I shut car off steams out of overflow and dumps on the ground..... any ideas ? guess Ill get a new radiator cap and hope my head gasket is ok thanks Scott
Sep 19, 2008 at 4:23 PM
  • 75,988 POSTS
Did you bleed the air out after you replaced all those goodies-if not do it and report back
Sep 19, 2008 at 4:30 PM
GTOSCOTTY
[quote:94764238fe="rasmataz"]Did you bleed the air out after you replaced all those goodies-if not do it and report back[/quote:94764238fe] bought radiator cap today, not sure how to blleed system in this car, my 97 firebird has bleed screws above the t-stat, ran car for about ten mins seems ok so far gonna drive later thanks
Sep 20, 2008 at 9:27 AM
  • 75,988 POSTS
BLEEDING COOLING SYSTEM
Always bleed air from cooling system after replacing coolant. Set heater for maximum heat. Remove radiator cap. Loosen drain plug and remove drain bolt (if equipped) from engine block. Drain coolant reservoir. Fill coolant reservoir to MAX mark with 50/50 water-coolant mixture. Loosen bleed bolt and fill radiator up to base of filler neck. Close bleed bolt when coolant flows out without bubbles. Tighten bleed bolt. With radiator cap removed, start and operate engine to normal operating temperature. Add coolant if necessary and check for leaks.
Sep 20, 2008 at 9:33 AM
