2006 Pontiac Montana Could brake repair cause AWD to be dis
2006 PONTIAC MONTANA
48,000 MILES • 6 CYL • AWD • AUTOMATIC
JAKIEM
Had new brakes and rotors. Next day received message that "AWD is disabled". Mechanic who did brakes said there was no connection. Dealer said that maybe mechanic used wrong rotors. Said need to use rotors with reluctors. Does this make sense?
Jun 26, 2008 at 9:27 AM
MERLIN2021
  • 17,250 POSTS
The reluctors are the ring gears, and if the new rotors don't have them it will disable the ABS, traction control and maybe the AWD, speed info is not input to the PCM without the reluctors..Have it rechecked!
Jun 26, 2008 at 9:31 AM
