2005 Pontiac Montana Blocked drain
2005 PONTIAC MONTANA
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
ANDY.JOBSON
The drivers side fllor remains wet and I think it is a blocked air conditioner drain. Where is the drain and how can I fix this
Aug 11, 2009 at 6:00 AM
  • 110,244 POSTS
If you look under the hood on the firewall (passanger side) you will see a black rubber hose going nowhere. Move it around because the clog usually happens right at the end where dirt can get.
Let me know if this helps.
Aug 11, 2009 at 11:34 AM
