2005 Pontiac Montana 2005 Pontiac Montana SV6 Front End Wob
59,000 MILES • 6 CYL • FWD • AUTOMATIC
RYAN KING
Between 44 and 62 MPH my steering wheel shakes quite a bit. Above 62 and below 44 there is no notable shake. Do you have any idea what would cause this problem? The rotors and brakes are less than a year old. The tires are less than a year old. It happens even if the tires are rotated so I have ruled out the tires and or rims.
I had the bearings replace on the front end in 2007. But did not notice this problem until the past 6 months.
Thank you,
Ryan King
Sep 2, 2009 at 1:18 AM
  • 110,244 POSTS
Have you checked steering components, especially ball joints? Also, when was the last alignment?
Sep 9, 2009 at 12:24 AM
