2004 Pontiac Montana factory alarm
118,000 MILES • 6 CYL • FWD • AUTOMATIC
RAR
factory alarm goes off every time a door is opened, and can't be shut off. It stops on its own after 2 minutes or so. I would like to either disable it or fix it. I dont care which.
Jul 20, 2009 at 12:22 PM
  • 110,248 POSTS
To the best of my knowledge, it can't be disabled. To make matters worse, dealers are the only ones that have the proper test equipment to check them to determine where the problem is coming from. Therefore, you will need to take it to a dealer to have the problem repaired.
Jul 20, 2009 at 1:40 PM
