2003 Pontiac Montana What next
117,000 MILES • 6 CYL • 2WD • AUTOMATIC
BOXTER
I have tried everything from tune ups to fuel filter replacement to transmission service and diagnosic, Fuel injecters inspected and cleaned. using the better gas and still i have a spudder while excellerating.
I have read what you have wrote to others and i still am in trouble.
I have no check engine light on.
There are no codes stating any problems.
Would any of the sensors like Map sensor, Throttle Sensor or Mass air sensor show up on a diagnostic if they were the problem.
If not then how do i tell whats wrong
HELP
Apr 13, 2010 at 10:21 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Ok, has the fuel pressure and regulator be tested? I see that you had the injector checked and cleaned and just wonderong about the fuel pressure.
A weak fuel pump can cause your symtom.
Does it run normally when driving at highway speeds?
As for any sensors being the problem the one that comes to mind would be the MAF Sensor, your can try cleaning it with some MAF Sensor Cleaner, DO NOT Use anything else to clean the MAF. You will end up replacing it if you do.
You can also check the IAC (Idle Air Control) Valve. It could have some carbon that has broken loose and causing it to not open or close properly.
Apr 13, 2010 at 11:59 AM
BOXTER
The fuel pressure or the regulator to my knowledge may not have been tested. I'm unsure
The van runs normally at higher speeds in city and on highway. Just when you start off and seems to run fine after that.
I can try the MAf sensor also have the IAC checked
Thanks for the feed back
Apr 13, 2010 at 11:21 PM
2 LINSEY
  • 287 POSTS
Hi boxter, we hope your getting it worked out. Let us know if there is anything else you need.
Apr 22, 2010 at 7:01 AM
