2003 Pontiac Montana Wet Floorboards
2003 PONTIAC MONTANA
89,000 MILES • 6 CYL • FWD • AUTOMATIC
HELGYUAL
THe floorboards are soaking wet especially under the passengers side. Under the center console there are theremains of some metal componenet but it is completely rusted away. I suspect the air conditioner drain is clogged (no antifreeze odor or loss and the water is clear) but don't know how to access it to check. I have removed the trim and some carpeting on the passenger side but can't get the center console out. Am I on the right track or should I be checking somewhere else? What's the fix?
Oct 25, 2008 at 3:02 AM
DENNYP
  • 1,824 POSTS
You can get to the drain on the other side of the firewall. (engine compartment side)
Oct 28, 2008 at 5:02 AM
