Front Blower motor not working
240,000 MILES • 6 CYL • FWD • AUTOMATIC
MARCPRO
My front blower motor stopped working suddenly. Does not work at any speeds. A/C is working, I get cold air coming out of the vents when I'm on the highway. All fuses check out OK, both on passenger side panel and on right hand side fuse block under the hood.
Rear blower works fine.
Thanks in advance for troubleshooting advice.
EDIT: 24 hours after writing the above, blower motor works again, all speeds work fine. I did absolutely nothing to fix it so far. Seems like an intermittent problem. I would still like to look at a troubleshooting tree to pinpoint the problem. Thanks for all the replies so far!
Jul 8, 2010 at 5:22 PM
SATURNTECH9
  • 30,869 POSTS
This sounds like the blower motor when out but to be sure lets run down this guide which shows how to test and replace the blower motor with diagrams below for how it can be done on your car.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
Cheers
Jul 8, 2010 at 6:42 PM
SATURNTECH9
  • 30,869 POSTS
Thank you so much for this post it was the blower motor for me cost $56.00 all fixed!
Aug 17, 2018 at 7:02 AM
KRYBABY
The front fan motor doesn't work but the back fan motor works fine. I can fill air when driving down highway.
Aug 17, 2018 at 7:03 AM (Merged)
HMAC300
  • 48,601 POSTS
check relay and resistor in pics I tmay be the control though which would have to be scanned by a pro.
NDWIG
My A/C and heater blower has stopped working on settings 1, 2, and 3 only. It still works fine on settings 4 and 5 on the dashboard controller dial. Can this be fixed?
  • 110,246 POSTS
Chances are the blower motor resister is bad. Have you tried replacing that? There is also a relay that can cause this, but my first guess is the resister.
