2003 Pontiac Montana Front Bearing
87,000 MILES • 6 CYL • 2WD • AUTOMATIC
DBNICHOL
I changed the front left bearing about a month ago, now it is starting to chirp sometimes. Did i tighten the bearing too much? i know that used to be an issue with bearings, but didn't think so any more.
Aug 21, 2008 at 4:16 AM
DAVIDC
  • 5 POSTS
It's most likely brake related or the splash shield is rubbing on the rotor.[quote:60dc530199="dbnichol"]Drive Train Axles Bearings problem
2003 Pontiac Montana 6 cyl Two Wheel Drive Automatic 87000 miles
I changed the front left bearing about a month ago, now it is starting to chirp sometimes. Did i tighten the bearing too much? i know that used to be an issue with bearings, but didn't think so any more.[/quote:60dc530199]
Oct 11, 2008 at 7:43 AM
