fluid keeps leaking out of cooling system, and i have had to refill radiator once per week for the last couple weeks. i beleive it is the water pump located on left side of engine that is leaking, but am not sure. when i have the engine running water seems to be getting on the belt because i can feel a small spray of liquid when i stick my face down in the engine compartment to try and see where the leak is. how could i make sure that it is the water pump and not a hose or even the radiator itself leaking?
Aug 10, 2009 at 12:15 AM
