2003 Pontiac Montana fluid leak from cooling system
2003 PONTIAC MONTANA
172,000 MILES • 6 CYL • FWD • AUTOMATIC
DAVID ULLMER
fluid keeps leaking out of cooling system, and i have had to refill radiator once per week for the last couple weeks. i beleive it is the water pump located on left side of engine that is leaking, but am not sure. when i have the engine running water seems to be getting on the belt because i can feel a small spray of liquid when i stick my face down in the engine compartment to try and see where the leak is. how could i make sure that it is the water pump and not a hose or even the radiator itself leaking?
Aug 10, 2009 at 12:15 AM
  • 110,244 POSTS
Chances are you are correct. Under the water pump is a seap hole (about 1/4" in diameter). That is where it will be leaking from. Check that and let me know what you find.
Aug 11, 2009 at 11:35 AM
