1999 Pontiac Montana Water Pump
1999 PONTIAC MONTANA
122,000 MILES • 6 CYL • FWD • AUTOMATIC
DHOWELL
I just had the water pump change because the mechanic said it was leaking. In looking at the engine and what I think is the water pump, it has not been changed. It has the 2" hose coming from the bottom of the radiator attached and is driven by the main accesory drive belt. If they put a new pump in is it possible that they didn't require changing the housing or did I get ripped off? It looks like they took the drive pully off from the marks on the attaching nuts.The pump cost $63 For total cost of $126.
Mar 17, 2009 at 3:53 PM
DAVE H
  • 13,384 POSTS
hello .. thanks for the donation .. much appreciated It is possible if the water pump was just leaking they have just replaced the gasket !! I have a price of $88 OEM dealer part for the pump .. I would take this up with the repair shop .. .. hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_stpats_1.jpg
Mar 17, 2009 at 4:16 PM
