2003 Pontiac Montana Brake lights - base of bulbs melting
134,000 MILES • 6 CYL • FWD • AUTOMATIC
AJACKSON234
The brake lights on both sides stop working after a relatively short time (I've replaced them more than 2x per year). The filament is fine. The base of the bulb is melted/overheated around the point of connection in the bulb socket. The bulb socket appears to be fine. I replaced both of them 6 months ago.
Something is obviously drawing too much amperage, but I don't know where to start looking or how to isolate the problem.
Any ideas?
Mar 14, 2010 at 6:42 AM
  • 110,248 POSTS
Have you tried replacing the socket?
Apr 24, 2010 at 5:47 PM
AJACKSON234
[quote:12a1124952="Jacobandnickolas"]Have you tried replacing the socket?[/quote:12a1124952]
Yep. The socket base is a unit that holds all 4 bulbs on each side. I bought replacements for both sides from Rockauto last fall. That didn't help. I don't think it's a problem with the contact between the socket and the bulb...the don't see burning on the bulb from a sparking short. The bulbs just look melted.
I know some part of the cruise control draws electricity downstream from the bulbs. When the bulbs are both fried, then the cruise stops working. Could that be the problem? Would an measure of amperage downstream after the bulb indicate too much draw? Do you know of any way to troubleshoot something like that?
Apr 25, 2010 at 7:32 AM
  • 110,248 POSTS
This is a good one. The only thing I can say is start with what you have suggested. Check how much draw there is to that circuit.
Apr 26, 2010 at 3:34 AM
JOHNIEMO
Mine is a 2003 model. Have you found any good way to systematically isolate the problem?
After the initial bulbs lasting what seemed like forever, each new set lasts a shorter and shorter time period. I had both brake lights out and was pulled over my police on April 5th. Replaced them that day and now my passenger side is out. I am down to them lasting about a month...it's ridiculous.
The plastic at base of bulb was melted. No other problems in electrical noted at this time...
Any suggestions because I am going to have to take it in and don't want to spend a fortune with them investigating and end up with a crazy huge bill.
Any help would be appreciated!
BTW the dealer is telling me to replace entire circuit board for each side. approx $56.00 each.)
May 6, 2010 at 9:42 AM
  • 110,248 POSTS
What part of the bulb is melting? Is it the plastic part that plugs in melting?
May 6, 2010 at 3:27 PM
