2003 Pontiac Montana Battery Replacement
JAZZBASS57
2003 Pontiac Montana 6 cyl Front Wheel Drive Automatic
I can't find the means to get the old battery out. I removed the fender brace and the + & - terminals. But the old battery still wont budge. I can't find where it is clamped to the battery box/plate. Can you help me out?
Oct 31, 2009 at 12:34 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Remove and reposition the underhood electrical center.
Remove the front end sheet metal diagnol brace.
Remove the battery ground cable from the battery.
Remove the battery positive cable from the battery.
Remove the battery hold down retainer
Remove the battery and battery unsulator.
I believe you are missing the hold down retainer. There should be a bolt attaching the hold down retainer to the battery tray. The retainer is what is keeping your battery held in place.
Oct 31, 2009 at 12:39 PM
