2003 Pontiac Montana battery,
DEB123
Engine Mechanical problem
2003 Pontiac Montana Two Wheel Drive 100,00 miles
won't turnover like dead batt everything thing else works, is there some kind of relay or fuse or what can i do to find out what it is
Aug 26, 2010 at 11:54 AM
  • 75,988 POSTS
If its not a security system issue. Could be the battery itself and connections if not start checking the starter motor , starter relay, park/neutral switch and ignition switch.
Aug 26, 2010 at 7:43 PM
