Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Pontiac
Montana
Brakes
Wheel Cylinder
2002 Pontiac Montana torque on rocker nuts
2002 PONTIAC MONTANA
GS AUTO
MEMBER
1 POST
2002 Pontiac Montana 6 cyl Front Wheel Drive Automatic
help on torque specs rocker nuts
Feb 18, 2010 at 1:08 AM
BLUELIGHTNIN6
Experienced Mechanic
the valve rocker arm bolt has two passes. first time tighten to 14 Lb Ft (19 N.m) , second pass is an additional 30 degrees.
for the valve rocker arm cover bolt tighten to 89 lb in. (10 N.m)
Feb 27, 2010 at 1:22 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine overheating
