2002 Pontiac Montana torque on rocker nuts
GS AUTO
2002 Pontiac Montana 6 cyl Front Wheel Drive Automatic
help on torque specs rocker nuts
Feb 18, 2010 at 1:08 AM
BLUELIGHTNIN6
  • 16,542 POSTS
the valve rocker arm bolt has two passes. first time tighten to 14 Lb Ft (19 N.m) , second pass is an additional 30 degrees.
for the valve rocker arm cover bolt tighten to 89 lb in. (10 N.m)
Feb 27, 2010 at 1:22 PM
