2002 Pontiac Montana replace rear sparkplugs
80,000 MILES • 6 CYL • FWD • AUTOMATIC
SAL SCELISI
can i use a jack under oil pan to rotate engine forward,after removing the two mounts above radiator thank you
Jun 23, 2008 at 1:58 PM
DENNYP
  • 1,824 POSTS
Be sure to put a block of wood under the pan first. Make sure it's not directly in the center of the pan.
Jun 24, 2008 at 9:20 AM
