2002 Pontiac Montana Low oil pressure light
2002 PONTIAC MONTANA
77,000 MILES • 6 CYL • 2WD • AUTOMATIC
PM02
I have low oil pressure light comes on at cold startup, goes out after 3-7sec. Checked oil level -good and for leaks - none. Valve cover removed - good oil flow.
Suspect oil sensor is bad? Where do I locate the sensor? How do I diagnose? Other opinions?
Jun 30, 2010 at 7:17 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Was engine oil the proper weight/vescosity when replaced? Need to check oil pressure with a mechanical gauge, visual inspection won't tell you if oil pressure is slightly lower than it should be..
Jun 30, 2010 at 7:20 AM
