2002 Pontiac Montana Brake light came on while driving and
2002 PONTIAC MONTANA
160,000 MILES • 6 CYL • FWD • AUTOMATIC
SHARON3360
While driving home my brake light came on and an indicator light with wavy sign in parintheses came on what does this mean?
Sep 1, 2009 at 3:41 PM
BLUELIGHTNIN6
  • 16,542 POSTS
check your brake fluid level and let me know how it is
Sep 1, 2009 at 3:53 PM
SHARON3360
brake fluid was low.. thank you
Sep 1, 2009 at 4:22 PM
HCROTTY
I have a 2003 Pontiac Montana with the same problem. I have put brake fluid in it and the lights still won't go off. Is there any other reason for this?
May 5, 2010 at 12:44 PM
BLUELIGHTNIN6
  • 16,542 POSTS
is it the ABS light or the yellow brake light thats on? do you have any trouble with braking?
May 5, 2010 at 1:26 PM
HCROTTY
It is the brake light and another one in the shape of a circle with a wavy design inside the circle.
May 5, 2010 at 11:13 PM
BLUELIGHTNIN6
  • 16,542 POSTS
For the brake light, make sure the e-brake is fully released and the master cylinder is full of fluid. You should be able to read ABS codes with a professional scanner, but my guess would be a faulty ABS sensor
May 6, 2010 at 1:09 PM
