2002 Pontiac Montana 2002 pontiac montana low air flow
2002 PONTIAC MONTANA
120,000 MILES • 6 CYL • FWD • AUTOMATIC
ADOG511
I have a 2002 pontiac montana and when you have the vent/floor switch on it has very low air flow and when you put it to just floor it has better air flow and when you put it to just vent it is a little better air flow than when you have it mixed. any suggestions . thanks
Apr 29, 2009 at 9:06 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:42d7c48756="adog511"]2002 Pontiac Montana 6 cyl Front Wheel Drive Automatic 120000 miles
I have a 2002 pontiac montana and when you have the vent/floor switch on it has very low air flow and when you put it to just floor it has better air flow and when you put it to just vent it is a little better air flow than when you have it mixed. any suggestions . thanks[/quote:42d7c48756]
Has the Cabin Air Filter evr been changed? If not I would start there.
It is locate behind the glove box. But is accessable from inside the glove box. OPen glove box at the left back side will be the access panel remove it to access filter (there are 2 filters) remove the first one then side the other over to openning and remove. Reverse proceedure to install.
Apr 29, 2009 at 9:45 AM
