2002 Pontiac Montana
BENNYBLANCO
Engine Cooling problem
2002 Pontiac Montana Four Wheel Drive Automatic
car gets over heated change thomrs- and water pump still over heats
Mar 7, 2009 at 11:23 AM
F4I_GUY
  • 3,302 POSTS
Are you running low on coolant? Get the coolant system pressure tested to make sure there are no leaks from the intake manifold or headgaskets.
If there are no leaks, ensure your cooling fan is coming on at the appropriate temperature and your radiator is efficient.
Mar 11, 2009 at 1:26 PM
