2001 Pontiac Montana Pressure Readings
220,000 MILES • 6 CYL • FWD • AUTOMATIC
RCG
I have hooked up a/c guages to lo and hi connections and I get a correct static pressure on both with car off ( mid 70's psi @ 80 ish degrees F ).
When car started and running for about a minute I press a/c button and here the ac kick in but only get hot air. The guages read lo - 32psi and hi - 100psi. All the a/c troubleshooting tips I have read has no information for these readings. They have lo lo - hi lo
lo high - hi high etc. with possible causes. I assume the compressor is kicked in because the lo and hi pressure guages change when the a/c button is depressed. Any help would be appreciated
Bob G.
Jul 9, 2010 at 6:34 AM
DOCFIXIT
  • 18,828 POSTS
What is vent temp? have you added 134A? system been opened? repairs?
Jul 9, 2010 at 7:23 AM
RCG
I have owned the vehicle since new. About 4 years ago a new compressor was installed by the dealer and it has worked fine till this year. The outdoor temp was 90 deg f. the vent temp was 100 deg f.
The first thing I did was buy a REDTEK charge kit which came with 2 cans of r12 compatible freon and a low pressure guage. The low pressure guage read slightly low so I added some freon. I then started the vehicle and obtained a reading in the low 30's but still got no cool air. I then hooked up a high pressure guage and got the readings as I originally stated.
Jul 11, 2010 at 5:47 AM
DOCFIXIT
  • 18,828 POSTS
Your system is filled with 134A you sure you put R12 compatable? if yes not good. Static reading should have been 90-100 and running Low 35 high 270-300 so system needed charging. But not with R12 compatable
Jul 11, 2010 at 6:24 AM
