2001 montana heater blower motor does not work. I checked all fuses and they are good. Tested for power at the motor connection and there is no power. Is there a fuse somewhere else other that the interior fuse panel or the engine compartment fuse block. the rear compartment heater is not working also, and the headlights will not turn on unless the switch is turned on. Would like to have heat in vehicle again.
Feb 23, 2009 at 8:19 AM
