Is there an access panel for the fuel pump under the carpet in my van?
Mar 30, 2009 at 3:24 AM
JAMES W.
✓Experienced Mechanic
No, you have to drop the fuel tank. An access panel would have been a good idea, but they never did it. I have heard of people "cutting" one in, but I would not recommend it.
Here is a guide to help and diagrams below to get the job done:
I am wanting to know if there is a access panel for the fuel pump or do I have to drop the tank?
Jul 2, 2018 at 10:46 AM
(Merged)
STEVE W.
Sorry, tank has to come down if you do it by the book. There are people who have cut the floor open but not something I recommend. Fuel vapor + spark while cutting = Not anything good!
(Merged)
27405205
MEMBER
We can hear the fuel pump running, there is fuel at the engine, but the van will still not start. If we manually inject gas at the throttle body, the van runs until this gas is burned.
(Merged)
BLUELIGHTNIN6
Assuming this is a fuel issue and that spark and compression are good, since the fuel is getting to the injectors but no further, you will need to test the injectors to ensure they are pulsing. If they are not, check fuses and relays. If they are then test the fuel pressure to ensure there is enough fuel being pushed through by the fuel pump.
