2001 Pontiac Montana Front turn signal light replacement
2001 PONTIAC MONTANA
RBREIT
The owners' manual says to unscrew the wingnut and the light assembly just comes out. Mine doesn't and seems like something else is holding it. What am I missing?
Thanks,
Rich
Jul 18, 2008 at 7:28 AM
SALESMANTONY
There are two wingnuts, one straight up, the other horizontal (at the top of the assembly). Also, the assembly has two "probes" at the back that go into a slot. They are a booger to get out, and you may have to get aggressive, but it will come out. I used a long flat tip screwdriver to "persuade" them.
Jul 19, 2008 at 8:44 AM
RBREIT
Thanks, however I came up with other descriptions than 'booger to get out'. I can't believe this design!!!!
Jul 21, 2008 at 5:41 AM
