2000 Pontiac Montana wind shield and signal arm broken
2000 PONTIAC MONTANA
HZN66
2000 Pontiac Montana 6 cyl Four Wheel Drive 111 th miles
My wind shield washer and left and right signals are not working. is this possible for me to fix myself ?. if not what would be the cost for me to get it fixed. and what parts would i need and what is the cost for part.
Jan 20, 2010 at 2:36 AM
BLUELIGHTNIN6
  • 16,542 POSTS
did it all stop at once?
first check fuses for the washer pump and also signals. check out the signal flasher relay as well. can you hear washer pump running when switched on? is the fluid level high enough to get pumped out?
Feb 27, 2010 at 1:26 PM
