HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Pontiac
Montana
Body
Wiper
Front wipers stow in up position
SEAMESD
MEMBER
PONTIAC MONTANA
I have a 1999 pontiac montana and the front wipers stow in the up position how can I get them to return to lower position?
Saturday, November 3rd, 2007 AT 8:45 AM
BLACKOP555
MECHANIC
Turn key off when wipers are in the down position.
Saturday, November 3rd, 2007 AT 2:59 PM
LOSTINMARS
MECHANIC
Either the wiper motor arm/clutch is bad or the tab on the cowl where it mounts has been bent and isn't triggering the return.
Sunday, November 4th, 2007 AT 2:21 AM
Please
login
or
register
to post a reply.
Related Wiper Content
Windshield Wipers Are Running Off The Windshield...
First Only The Passenger Wiper Ran Off The Edge. Now After I'd Tried To Realign Them Per These Specs: "lh- 147 Mm Above The Glass Blackout...
Asked by
ricky946
1998
PONTIAC MONTANA
VIDEO
Fix Annoying Wiper Chatter on Windshield
Instructional repair video
GUIDE
Wiper Chatter
Windshield wipers are supposed to work freely while wiping the water from the glass surface in a uniform manner, enhancing the visibility for the driver and passengers of...
When The Wipers Are In Intermittent Mode, They Park...
When The Wipers Are In Intermittent Mode, They Park Up Instead Of Down. Somehow Electrical? Wiper Transmission?
Asked by
Anonymous
1 ANSWER
2000
PONTIAC MONTANA
Replacing Grill
What Is The Procedure (step By Step Instructions) For Removing And Then Replacing Both Grills On A Pontiac Montana 2002? Any Special Tools...
Asked by
Nighthawke
1 ANSWER
3 IMAGES
2002
PONTIAC MONTANA
Loud Buzzing Coming From Under Back Passenger Side...
I Have A 2000 Montana Mini Van And When I Put It In Drive Or Reverse It Makes A Loud Buzzing Noise That Comes From Under My Pasenger Side...
Asked by
judy.crutchfield
2000
PONTIAC MONTANA
I Need To Pull Out The Frame
My Car Was Wrecked In A Ditch And I Need To Pull My Front Frame Out A Little Bit So I Can Replace The Radiator. How Can I Pull The Frame Out...
Asked by
ashley9269
1 ANSWER
1999
PONTIAC MONTANA
VIEW MORE
Replace Windshield Wipers Toyota Prius
Replace Windshield Wipers Ford F-150
