2000 Pontiac Montana Thermostat
140,000 MILES • 6 CYL • FWD • AUTOMATIC
BOBKURON
The engine quickly over heated, not gradually. Do you think I am dealing with a thermostat or a water pump?
Aug 31, 2009 at 3:05 PM
BLUELIGHTNIN6
  • 16,542 POSTS
failing or weak water pumps normally create a very loud noise and also weep coolant from its weep holes. you will need to remove the thermostat and test it to see if its opening properly . did you notice if cooling fan(s) come on?
Aug 31, 2009 at 3:30 PM
