2000 Pontiac Montana Strange whistling noise...
2000 PONTIAC MONTANA
87,000 MILES • 6 CYL • FWD • AUTOMATIC
NAROKSAAR
My car makes a strange whistling noise when I accelerate. It started a few months ago and originally only happened when I was traveling over 60mph (as soon as it went over 60 it would start) now it is a more constant noise. Any idea what it could be?
Jun 15, 2009 at 4:03 AM
  • 110,240 POSTS
Have you checked for vacuum leaks?
Sep 9, 2009 at 1:22 AM
ICECITY HOLDON
I have a Pontiac Montana van 2001 when I press the gas pedal a whistling noise begin to make noise I change the belt and check the pulleys but that wasn't a problem so what do I do now
Feb 9, 2017 at 3:13 AM
  • 31,937 POSTS
Check for vacuum leaks, often this is the problem.
Feb 11, 2017 at 6:57 PM
  • 55,224 POSTS
Hey all,
This could be a problem with a plugged exhaust system. Here is a guide to check it out
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Please let us know what you find so it will help others.
Best, Ken
Feb 13, 2017 at 1:33 AM
