2000 Pontiac Montana overheating
125,000 MILES • 6 CYL • FWD • AUTOMATIC
SYSSMOVICH
van has normal tempature when idling, when you start to drive it races up to the the over heating stage on the guage and will slow the van down. water pump recently replaced. also had headgasket replaced. shop that did both repairs says they pressure tested it and it checks out alright. serpentine belt new to. still think there's a compression leak somewhere. when the shop did the headgasket had to weld the head because it was pretty pitted. help!!!
Oct 16, 2010 at 11:53 PM
KHLOW2008
  • 41,812 POSTS
Hi syssmovich,
Are the cooling fans working?
Do you have coolant losses issues?
Did you check the coolant level in radiator?
Oct 17, 2010 at 3:00 AM
