2000 Pontiac Montana overheat
TIMGMMN
Engine Cooling problem
2000 Pontiac Montana 6 cyl Front Wheel Drive Automatic
new pump, new thermostat, flushed system ,refilled and bled. Coolant is full, still overheating and heater cold. Heater core? Would that make it overheat?
Dec 30, 2009 at 7:39 PM
BLACKOP555
  • 10,386 POSTS
was heat working before you did all of your work?
get car warm and feel heater core hoses. if they cold or warm suspected restricted hoses, cores or air in line. if they both hot then it is in the air ducting.
Dec 31, 2009 at 4:52 AM
