i have done all required maintnance i even replaced water pump thermostat hoses and belts and it still over heats
Aug 6, 2010 at 9:59 AM
✓Experienced Mechanic
Radiator and Cap okay-if so coule be air in it-try bleeding it don't work-get block and pressure tested to rule out the head gasket, cracked head or block or an intake leak-also check the catalytic converter if its clogged-cooling fans
