2000 Pontiac Montana oil leaks
125,000 MILES • 6 CYL • FWD • AUTOMATIC
RONNANGIEHIL
i see oil cumming from the top of the engine like on the intake manifold is there any problem spots bye there. it is like running out and dripping out just idling
Nov 19, 2008 at 2:58 PM
  • 31,937 POSTS
Hi there ,
The most common spot would be the rocker cover, wash the engine down & check to see if it is there, you may be able to tighten it down again or replace the gasket.
Mark (mhpautos)
Nov 19, 2008 at 3:05 PM
