1999 Pontiac Montana Replacing Head Gasket
1999 PONTIAC MONTANA
166,000 MILES • 6 CYL • FWD • AUTOMATIC
TODD1234
I am in the process of replacing the front head gasket for a Coolant problem that is known for these engines. I am having problems removing the engine strut bracket from the passenger side. I have found two bolts, so far and a compression type stud that the bracket fits over. Any advice on removing this bracket? It will not come loose and I have not went to extreme measures...yet.
Mar 3, 2009 at 8:10 PM
BMRFIXIT
  • 19,053 POSTS
I would recheck the leak area
as I would suspect the intake manifold gasket
its more common for it to fail and cause a leak at around the head area and on top of the tranny and by the front too
as for the bolt I’m not sure what is it you r trying to do,,,, sorry
Mar 3, 2009 at 8:21 PM
TODD1234
I am trying to remove this strut bracket so I may remove the exhaust pipe. I have had a mechanic look at the vehicle and determine that there is a head gasket leak...unless he was wrong. I did a compression test. I do believe it had a manifold leak also but would a manifold leak result in poor compression on the cyclinder?
https://images.2carpros.com/forum/automotive_pictures/326461_engine1_1.jpg
Mar 3, 2009 at 9:43 PM
RUNNINGCRO
i am redoing the heads on my 1999 pontiac montana also. There is another bolt on the bottom of that bracket, you have to unbolt you air conditioner pump to remove it.
Apr 17, 2009 at 8:50 PM
