1999 Pontiac Montana NOT CHARGING
155,555 MILES • 6 CYL • 2WD • AUTOMATIC
STANLEYTREES
I HAVE REPLACED THE BATTERY AND THE ALTERNATOR, AND IS STILL NOT CHARGING THIS IS THE THIRD ALTERNATOR I'VE PUT IN THIS VAN, WHAT DO I HAVE TO LOOK FOR, FRIENDS VAN- HE SAID HE TOOK TO A MECH, AND THEY REPLACED SOMETHING IN THE BRAIN BOX WITHIN THE AIR FILTER BOX,EIC OR SOMETHING TO THAT NATURE
Dec 24, 2007 at 8:31 AM
  • 31,937 POSTS
Check the alternator charge rate at the main terminal at the alternator, you will want approx 13.4 to 14.5 Volts, If not, the alternator and /or the voltage regulator is faulty. Start there.
Mark (mhpautos)
Dec 24, 2007 at 9:38 PM
