1999 Pontiac Montana fumey odor
144,896 MILES • V8 • 2WD • AUTOMATIC
KDAWKI01
My low-coolant light blinked on then off....though I have a shortage because my abs and service engine light stays on. I finally checked the antifreeze and it wasn't any. I filled it and it began to get hot. now there is thick grayish white smoke coming from the exhaust and it has a fumey odor like coolant and oil. I did have the thermostat changed. Bit it is still doing this.
Mar 25, 2010 at 2:25 AM
  • 110,246 POSTS
If you are getting grayish white smoke, you have a bad head gasket. When coolant gets into the combustion chamber, it produces white smoke when it burns.
Check engine compression and I feel you'll find one or two cylenders with low compression.
Let me know what you find.
Apr 24, 2010 at 5:40 PM
