1999 Pontiac Montana fuel pump won't work unless its hot wi
1999 PONTIAC MONTANA
JEWBUB
Electrical problem
1999 Pontiac Montana 6 cyl Front Wheel Drive Automatic
my fuel pump is brand new and work fine but i have to hot wire it to the battery to make it work the preasure is good the fuse is not blown.is there like a hidden relay somewhere in the wireing harness.thanks for any help
Sep 12, 2010 at 2:52 AM
Inspect and test the fuel pump relay and the fuel pump and oil pressure sending unit
Sep 12, 2010 at 10:16 AM
