1997 Pontiac Montana turn siganal
1997 PONTIAC MONTANA
BURNZE
1997 Pontiac Montana 6 cyl Front Wheel Drive
On my 97 montana the left turn signal works when the headlights are off but the display lights in the interior flash. But with the headlights on the left signal does not work. I've changed both front and rear bulbs. There is no problem with the right signal. What could be the problem?
Jan 10, 2010 at 7:25 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check for faulty ground wire at that specific signal assembly
Jan 16, 2010 at 6:38 AM
