1993 Pontiac Lemans timing
CDOBSON
Engine Mechanical problem
1993 Pontiac Lemans 4 cyl Two Wheel Drive Manual
how do you set the timing on a 1993 pontiac lemans 1.6 liter I set the lifter pulley dead top and the crank pulley dead top the car starts but has a loap am I setting it wright
Apr 6, 2008 at 2:28 PM
LEIFEARLY
I am thoroughly under experienced, but from other research I've done today I believe the crank pully should be dead bottom instead.
Nov 25, 2012 at 5:11 PM
