1992 Pontiac Lemans fuel pump
PWORMSBAKER
Engine Mechanical problem
1992 Pontiac Lemans 4 cyl Front Wheel Drive Automatic
was driving and vehicle quit running altogether,
will turn over but not start
Dec 1, 2008 at 7:51 AM
  • 75,988 POSTS
Do below to determine if its a fuel or spark problem and comeback with some results.
Get a starting fluid or ether and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Dec 1, 2008 at 8:05 AM
