1992 Pontiac Lemans Engine swap
1992 PONTIAC LEMANS
SCOTTWHITTY
Engine Performance problem
1992 Pontiac Lemans 4 cyl Front Wheel Drive Automatic
Ok, well, I wanted to upgrade the 74bhp engine to something around 250-300bhp. I heard that a Sunbird of the same year can be found with a turbo charged engine. Now, granted, if I use the Sunbird computer and wiring harness what other issues might I be running into here? Or perhaps maybe a 99 Sunfire GT (more recent then a sunbird) I guess really what I'm asking is, does anyone know if I can even do this without really going retarded with mods? I don't want to spend 5 grand doing this.
Oct 17, 2008 at 11:30 AM
MERLIN2021
  • 17,250 POSTS
If you swap the PCM and the exhaust I believe is different, you should be ok.
Oct 19, 2008 at 1:36 AM
SCOTTWHITTY
So will a stock turbo charged sunfire engine fit this vehicle? What engine is faster and more reliable in your opinion?
Oct 19, 2008 at 3:01 AM
MERLIN2021
  • 17,250 POSTS
If the turbo engine has been maintained, it is a better motor, Should fit.
Oct 19, 2008 at 3:08 AM
SCOTTWHITTY
Ok, sorry for the fuss. I want to make sure I'm clear here. What year Sunfire GT Turbo engine will fit my 1992 Lemans? Also it is my understanding that all I will need to change is the PCM and the exhaust, correct? Will my stock tranny take the load? More then happy to donate to you guys again, your help is greatly appreciated.
Sincerely,
Scott
Oct 19, 2008 at 3:14 AM
MMPRINCE4000
  • 8,548 POSTS
[quote:2a4cf8befe="scottwhitty"]Ok, sorry for the fuss. I want to make sure I'm clear here. What year Sunfire GT Turbo engine will fit my 1992 Lemans? Also it is my understanding that all I will need to change is the PCM and the exhaust, correct? Will my stock tranny take the load? More then happy to donate to you guys again, your help is greatly appreciated.
Sincerely,
Scott[/quote:2a4cf8befe]
To add to what Merlin said, the Lemans was built for Pontiac by Daewoo, so I don't think you will have any GM engine that will "bolt in".
The Sunfire turbo engine will most likely be hard to find, since they were only built a few years and built in (the engine) Brazil. This is not like putting a 3.1 V6 in a 4 cylinder Grand Am (which was offered in the Grand AM).
You will most likely have to remove the Daewoo engine, fit the Sunfire engine to the compartment, fabricate new mounts, check the fit or the drive axles into the stock knucles or use the entire transaxle from the Sunfire, check the length of the axles compared to the old ones, see if stock linkage works or fabricate new linkage mounts.
You will also have to use the Sunfire engine harness and marry that to the Lemans harness, use the Sunfire ECM.
Point is that while you may get all the hard parts within your budget, there will be a lot of labor and time involved and I would hate to tell you that it will work, only to find out that you may need to get new axles made because the originals are too short/long.
Some swaps are easier than others, unless you can find someone who has done it, you would be the first and would have to use the trial and error process to see if it will work.
Oct 20, 2008 at 1:04 AM
MERLIN2021
  • 17,250 POSTS
Thanks for the assist, I was NOT thinking about Daewoo lemans!
Oct 20, 2008 at 7:33 AM
MMPRINCE4000
  • 8,548 POSTS
No problem Merlin, you have helped me many times.
Oct 20, 2008 at 10:10 PM
