1991 Pontiac Lemans timing belt
12,500 MILES • 4 CYL • FWD • MANUAL
HOWMAN
Not to sure how the belt is threaded through
Oct 4, 2009 at 8:53 AM
DOCFIXIT
  • 18,828 POSTS
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_173.jpg
This is an interference engine did belt break? if yes valve damage has occured.
Oct 4, 2009 at 9:07 AM
HOWMAN
I put a new belt on it, but it is not starting up. What is the cost to fix something like this?
Oct 4, 2009 at 11:12 AM
DOCFIXIT
  • 18,828 POSTS
SoT-belt broke engine running? if yes check compression any cylinders down will have bent valve.
Figure @$ 700-$800 range
Oct 5, 2009 at 8:10 AM
