1989 Pontiac Lemans Dash Removal to Fix AC + Heater airflow
1989 PONTIAC LEMANS
111,000 MILES • 4 CYL • 2WD • AUTOMATIC
LYOKOFREEZE
Ahoy All Car Brainiacs!
Got an 89 Lemans (1.6L) , and I must say, even though its been a major pain to fix everything that keeps going wrong, its been a good little car. Currently I've got some pretty major issues regarding air flow in the air system. Only 2-3 Vents get air coming out of them, the rest have nada. I would like to remove the dash to try and fix this, however, I don't know how to go about that. Help please?
Also. I'm having a pretty substantial issue regarding a misfire. Heres the things I've tried so far:
-Plug Wires
-Distrib. Cap
-Ignition Rotor
-Ignition Coil
-MAP Sensor
-O2 Sensor
-TBI Rebuild including sensors
-Coolant Temp Sensor
-Oil Pressure Sensor
-K+N Air Filter Cleaner
-Spark Plugs still look good.
Help Please?
Jul 14, 2009 at 1:34 PM
BUDDYCRAIGG
  • CERTIFIED EXPERT
  • 2,262 POSTS
if you will email me your VIN. and give me a fax number i will send you an exploded view of the dash.
it often helps take things apart to see how it's put together.
also please include a little note about what your are looking for.
thanks
buddycraigg@gmail.com
Jul 20, 2009 at 8:54 PM
