1981 Pontiac Lemans battery keeps dying
93,000 MILES • 6 CYL • 2WD • AUTOMATIC
THOMASJ68
The battery in my car keeps dying and it is the third one in less than 6 months and I just replaced the alternator. After 2 or 3 times of starting the engine, it dies completley and I have to jumpstart the car. Also while the engine is running, if I disconnect the positive battery terminal, the engine cuts off.
Apr 19, 2009 at 1:30 PM
BMRFIXIT
  • 19,053 POSTS
Suspect charging system
if not the alternator check voltage regulator and fuses and wires
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Apr 19, 2009 at 1:45 PM
