1971 Pontiac Lemans seals
1971 PONTIAC LEMANS
PETRIE232005
1971 Pontiac Lemans V8
There are 2 seal that are on the timing cover that go under the water pump is there any special tool or way to get those off without replacing the tiiming cover ??? thanks i have bought the two seal and need help to get them off thanks
Aug 4, 2009 at 5:14 PM
You need a vibration damper puller to pull out the harmonic balancer than pry off the front oil seal carefully.
Aug 5, 2009 at 4:04 AM
