1970 Pontiac GTO Flat spot when exceleration
70,000 MILES • V8 • 2WD • MANUAL
MRGREENSBURG
My 1970 GTO with stock quadrajet carb,
has a flat spot/ hesitation when first excelerating.
Carb was rebuilt once and problem continued.
Look at and replaced excelerator pump and
still boggs. Any ideas? Thanks
Dec 17, 2009 at 10:41 AM
  • 75,988 POSTS
Sounds like its coming from the Carb could be the Acc pump or power valve and if not check the distributor vacuum advance unit
Dec 17, 2009 at 9:59 PM
