Engine Mechanical problem
1967 Pontiac GTO V8 Two Wheel Drive Manual
1967 GTO Just O/H the enging when installisng the cam shaft gear I lined up the timming marks facing each other. Now when I turn the engine over and get number 1 on comp. stroke the timming marks are both at 12 oclock. Then set the dist where it is firing on number 1. But when you go to start it you have to turn the dist clockwise to get it to run it sounds ok but wont idle and when you try to set the timming the closer you get to where the timming should be the slower it runs and quits before you can aline the timming marks. I have doubbled check the timming gear marks. Can th eprobleme be in the dist or the new cam I installed?
Mar 3, 2010 at 7:33 AM
